Re: Re: Re: Exhaust pipe for 1950 H
Posted by Farmall Gray on April 03, 2002 at 18:28:54 from (205.188.193.174):
In Reply to: Re: Re: Exhaust pipe for 1950 H posted by Grant on April 03, 2002 at 07:35:24:
That is a good idea EXCEPT it will be a P.I.T.A. when you need to take the hood off. Originally they used the strap type clamp and it was above the hood. This made it easy to take off to remove the hood. Of course they didn't care about a little soot on the hood when they designed the tractors.
Post A Followup
: Re: Re: Re: Re: Exhaust pipe for 1950 H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
