Re: Bad clutch release bearing???
Posted by Dale on April 03, 2002 at 20:19:25 from (12.93.73.154):
In Reply to: Bad clutch release bearing??? posted by Bama Binder on April 03, 2002 at 08:56:25:
The 184 has a release bearing like other IH tractors check to see if the release bearing fork has spread apart at the top ,if it has it canot engauge the pressure plate because the fork slides past its notches .I have seen a lot of 184s do this,if it has its an easy fix.
Post A Followup
: Re: Re: Bad clutch release bearing???
