Re: H going uphill???
Posted by Zonie on April 03, 2002 at 23:05:14 from (64.12.106.42):
In Reply to: H going uphill??? posted by Charlie in Cincinnati on April 03, 2002 at 10:00:08:
I have a couple things to consider.
you are new to using this tracto, as you begin to get more acustomed to it you will be able to sense whe the front end is getting light.On my H I can feel the front bolster bouncing on the pivot shaft since there is some play up and down. Also if I feel there is reason to worry I keep a close eye on the front wheels, if they start to lift you can always push in the clutch and get on the brakes.
Keep the tractor in the highest gear that it will pull the hill. The higher your gear the less likely it is to lift up the front end.
Post A Followup
: Re: Re: H going uphill???
