Re: waterfilter
Posted by Old Dutch on April 04, 2002 at 02:45:07 from (66.191.112.67):
In Reply to: waterfilter posted by ed on April 03, 2002 at 18:38:18:
Ed, when I worked for IH, when those kits were the big thing for anti-cavitation=causing pitting of the sleeves. We did some research with the University and some other diesel manufactures that had run into that. Well it so happened that it was being caused by an additive that some of the manufacturers were using in the anti-freeze solution, mainly for aluminum engines. So make sure that when you add any permanent solution, it is for your application,not aluminum engines. But by all means, add the kit. Good luck.
Post A Followup
: Re: Re: waterfilter
