Re: Super MTA brake pinion shafts
Posted by chris on April 04, 2002 at 16:29:35 from (65.69.164.206):
In Reply to: Super MTA brake pinion shafts posted by Merlin in Saint Paul on April 04, 2002 at 16:18:09:
I ground the splines on my 560 to smooth out the ridges from the brake disks,I used a air cutoff tool ,kinda like a die grinder with a real small chop saw blade. anyhow my brakes don't stick anymore. also when you put it back together use a very small amount of grease on the splines
Post A Followup
: Re: Re: Super MTA brake pinion shafts
