Re: Re: IH Industrial
Posted by John on April 04, 2002 at 19:27:12 from (162.39.174.193):
In Reply to: Re: IH Industrial posted by Haas on April 04, 2002 at 05:25:14:
I will be posting a photo in the next day or so, which should help in info on this machine. As for numbers, the ID plate has been painted several times, the numbers are not readable. The casting numbers are all that I will be able to get for now. A friend of mine looked at it today and said that it resembles his 240 quite a bit, but a photo of a 1958 340 is the closest I have seen. The PTO handle is broken, and the PTO won't engage, a real show stopper at this point. Tractor also has engine, starter, and carb problems, none of which seem major.
Post A Followup
: Re: Re: Re: IH Industrial
