Re: Re: M radiator removal, and other ????'s
Posted by boog on April 04, 2002 at 20:17:33 from (66.73.129.244):
In Reply to: Re: M radiator removal, and other ????'s posted by Michael Soldan on April 04, 2002 at 20:07:50:
Just a couple of quick comments.
First, try using JB Blaster instead of WD40. Was a firm believer in WD40 until a couple months ago. Owner of the neighborhood auto supply house got me to try JB Blaster. Used 1 can and went back and bought a case. Keep a can of WD40 around, as Blaster will not displace moisture.
Second, careful where you use a gear wrench. I was taking a nut off a stud one day with one and wasn't paying close attention and backed nut off to far and could not get wrench off due to clearance. Was stuck as I couldn't reverse the wench to tighten nut back up. Ended up having to cut the stud off, remove the part and use an easyout to remove the stud.
boog
Post A Followup
: Re: Re: Re: M radiator removal, and other ????'s
