SMD power steering on M
Posted by Jerry in Calif. on April 04, 2002 at 21:08:05 from (64.24.32.176):
I just bought a '53 SMD to use as a parts tractor. I also have 4 Ms and was wondering about using the PS from the SMD on one of them. Mounting the pump dosn't look too bad and I don't think the steering shaft is a problem. Will the crank pulley off the SMD fit the M or are there other options ..... or problems? Thanks to all for your advice and comments.
Post A Followup
: Re: SMD power steering on M
