Re: HEY Steven@ND!!
Posted by Steven@nd on April 05, 2002 at 05:15:43 from (12.23.184.8):
In Reply to: HEY Steven@ND!! posted by Mike ISW on April 04, 2002 at 20:06:09:
I spent about 45 minutes at the local Hedahl's trying to get something rigged up for this gauge. I will list the part numbers and prices just in case you have a Hedahl's near you.
1/4" x 40" brake line (AGS BL440) $2.89 [I was going to go with a 30" brake line but the original oil line is about 35" so 40" was the next step up - I'm sure there will be room to put an extra loop in if I have to.]
1/8" adapter (EDE 203200) $1.04 [this is a coupler that has 1/8" tapered female on both ends, screw this onto the back of the gauge]
1/4" x 1/8" elbow (EDE 122420) $1.13 each, you need 2 of them. [one of these screws into the adapter on the back of the gauge, it has 1/8" taper and 1/4" brake line fitting. The other one screws into the block behind the oil filter case so that you can hook up the brake line there.]
Here are some pics:
third party image
This is the end of the line that will go to the block.
third party image
This is the other end hooked to the gauge.
third party image
Another shot of the gauge end.
third party image
This is the whole unit set together.
third party image
These are the necessary fittings, along with the brake line.
Hope this helps someone out!
Steven
Post A Followup
: Re: Re: HEY Steven@ND!!
