Re: FARMALL (A) ENGINE BLOCK
Posted by Slavage Man on April 05, 2002 at 13:57:39 from (198.247.178.197):
In Reply to: FARMALL (A) ENGINE BLOCK posted by JONATHAN MIRGON on April 05, 2002 at 09:34:23:
The only thing that is different is the size of the O-ring at the bottom of the sleeve. Your A would have a 3-5/16 O-ring and the other size is 3-7/16. As far as I know there weren't any blocks built with out the place for the hydraulic pump that had the 3-7/16 O-rings. Other than the sleeves the all of other parts will all interchange.
Post A Followup
: Re: Re: FARMALL (A) ENGINE BLOCK
