Re: Oil Gage
Posted by Bob M on April 06, 2002 at 07:00:59 from (66.66.72.246):
In Reply to: Oil Gage posted by REA on April 06, 2002 at 05:51:17:
Bob - It's not exactly normal, but it's not unusual either. Means you've got a worn oil pump and/or a loose motor. So long as the gage shows any pressure indication >0 at idle, then comes up into the white range when the RPMs are above idle I wouldn't worry about it. Changing 15W-40 oil will bring the pressure up a bit, especially when the motor is hot.
Also try temporarily swapping the IHC oil gage for a known good gage. As long as you see at least 2 - 4 psi pressure when idling hot, you're motor will be OK.
Post A Followup
: Re: Re: Oil Gage
