Re: Re: Price for an M
Posted by Dick Davis on April 07, 2002 at 03:30:53 from (152.163.204.47):
In Reply to: Re: Price for an M posted by Mike ISW on April 06, 2002 at 19:45:56:
Depending on where you are located, you should be able to find a running M for that kind of money. Unless the truck wide front end has been welded in place (or the tractor cut up to accept) you should be able to replace with a narrow front for cheap. Stuck engines usually are more expensive to fix than frame stuff. And many 3 points are junk. We careful before buying and when heavy lifting. Dick
Post A Followup
: Re: Re: Re: Price for an M
