Re: Re: Stuck Farmall H Value
Posted by Question for Denny from Paul on April 07, 2002 at 10:56:00 from (66.187.35.147):
In Reply to: Re: Stuck Farmall H Value posted by Denny Frisk on April 07, 2002 at 08:05:55:
Were do you get 4 new tires mounted on an H for $500? The last tire a got mounted on my H a Kelly-Springfield cost me $300 then the 2 front tires with tubes cost $100(Firestones) and I mounted those my self. sizes are 12.4-38 and 5.50-16.
Post A Followup
: Re: Re: Re: Stuck Farmall H Value
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
