Re: Motor swap ?
Posted by SAm in NS on April 07, 2002 at 14:36:41 from (24.138.19.199):
In Reply to: Motor swap ? posted by Paul Shuler on April 07, 2002 at 12:52:17:
Although I really have no idea about it bolting up (although I think it will) there are a couple of things. The C-123 has a water pump whereas the C-113 relies on a thermosyphon cooling system. The C-123 will also have a place for a touch control hydraulic pump and the C-113 for a B will not. While I don't think these things would cause any real problems (might be problems with the radiator caused by the water pump? He would also need to install a thermostat). There are probably some other things that I've forgotten that I'm sure others will mention. Good luck. SAm in NS
Post A Followup
: Re: Re: Motor swap ?
