Re: OUCH!!! Sheared bolt!!!
Posted by Hugh MacKay on April 07, 2002 at 16:30:28 from (64.228.14.29):
In Reply to: OUCH!!! Sheared bolt!!! posted by Tim Malin on April 07, 2002 at 15:35:15:
Tim: Trying to figure which bolt, it must be bolt into casting or you wouldn't be in trouble. While your figuring what to do put penetrating fluid on. Probably your best bet is centre punch bolt drill it and use easy-out. Your probably going to need heat. There are acetylene guys that can burn bolt with torch and not hurt casting. They are few and far between, and I think they would need quite strong credentials before I would let them try. Hugh
Post A Followup
: Re: Re: OUCH!!! Sheared bolt!!!
