Re: Farmall A Hydraulics
Posted by Brian on April 07, 2002 at 17:17:27 from (66.185.84.197):
In Reply to: Farmall A Hydraulics posted by Steve on April 07, 2002 at 15:16:48:
I've seen and have a PTO driven valve,resovoir and pump "all in one" unit. It works very well. It's mounted with a simple plate, one of the things I really like about it is that it didn't alter the tractor in anyway, therefore preserving the original state. You could also run a pump off the front crank with a little modification to the pulley if you wanted.
In Canada I used a place called www.princessauto.com if you go to their site and download the PDF hydraulic catalogue you may get some ideas.
Post A Followup
: Re: Re: Farmall A Hydraulics
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
