Re: Farmall MD Starting Problems
Posted by Haas on April 08, 2002 at 05:27:15 from (129.37.117.89):
In Reply to: Farmall MD Starting Problems posted by Karl on April 07, 2002 at 20:27:09:
Check your plugs, and all the ignition parts. Check your switchover mechanisms, especially the connections to the carb and the butterflys in the manifold. When you are in gas mode, the butterflys in the manifold are positioned to direct air through the carb. When you are in diesel mode, the carb float is locked up to prevent gas flow to the carb. Maybe the float is sticking and not dropping down to let gas flow. Check that you have gas flow to the carb. Also, you may want to check clearance on the decompression valve mechanism to be sure they are opening to spec in gas mode. I find on my MD, that it requires choke to run and the engine has to be completely warm before it runs good on gas without the choke. Also how are you shutting down. You need to switch to gas to shut down and let all the gas run out of the carb. Be sure to switch the start lever back to diesel after it dies on gas. Switching to gas for shutdown makes the next start easier, as it burns out residual diesel in the cylinders and the decompression chambers. If everything is like it should be, the MD should start easily on gas.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
