Re: Re: OUCH!!! Sheared bolt!!!
Posted by shannon on April 08, 2002 at 07:17:38 from (146.186.68.21):
In Reply to: Re: OUCH!!! Sheared bolt!!! posted by Michael Soldan on April 07, 2002 at 16:42:12:
i would avoid the water and use an oil instead. water is such a good conductor of heat that it is possible, however not likely, to crack your casting. the water will cool the outside of the cast while the inside stays hot creating thermal stress. oil on the other hand has a lower heat capicity than water and is safer to cool somthing with, plus as an added benifit some oil may be sucked in around the threads by capilary action as it cools.
Post A Followup
: Re: Re: Re: OUCH!!! Sheared bolt!!!
