Re: 806 Loader
Posted by cb on April 08, 2002 at 12:51:41 from (207.54.105.157):
In Reply to: 806 Loader posted by Dave on April 08, 2002 at 10:54:42:
An IH 2350 mount o matic should fit ok. You may need to drill some 5/8 holes in the frame rails for the mounting brackets.And the tractor needs two hyd.valves to run it. The 2350 is an easy loader to mount or unmount in 3 to 5 minutes and dont need any wrenches.The long hose are the only big to handle.
We have mounting brackets on our 756D and 826D so we can use it on ether tractors. The brackets on the 756 we fabricated ourself's and work just as well as the set that came with the loader.
Post A Followup
: Re: Re: 806 Loader
