Re: 1971 Cub Clutch
Posted by elwood on April 08, 2002 at 17:29:44 from (66.133.134.24):
In Reply to: 1971 Cub Clutch posted by Charles W. Story on April 08, 2002 at 15:19:49:
hi charles, i am in the process of haveing same problem, i bought a 51 cub. it gringed going into gear, i tryed adjusting the clutch, it got worse.i took bottom inspection cover off and found pieses. i ended up spliting my cub to put in a new clutch. i was able to split my cub in under 3 hours. i hope you get lucky and dont have to spilt it. good luck. new clutch kit runs about $200 or less. i found one threw valebuilt for $150
Post A Followup
: Re: Re: 1971 Cub Clutch
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
