Re: M will only run with choke closed
Posted by jal-SD on April 08, 2002 at 19:30:24 from (64.68.166.199):
In Reply to: M will only run with choke closed posted by H.B.Hutchens on April 08, 2002 at 18:07:17:
Make sure the connection between governor & carb is correct. It'll go together in the wrong slot if you don't get it just right when you are putting the carb on & will give all kinds of grief before its found sometimes. (Don't ask how I know this one.) (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: M will only run with choke closed
