Re: Re: a lift
Posted by DAVE C on April 08, 2002 at 19:49:50 from (209.197.177.97):
In Reply to: Re: a lift posted by badger bob on April 08, 2002 at 18:39:53:
B.BOB; Good to hear that i was on the right track! you`ll be pleasantly surprised how well the lift works once you get a new seal and re-assemble.you will feel a bit of resistance when you lower ; that is normall, and you will get a proper neutral setting which will take the exhaust pressure off your exhaust valves when you aren`t lifting .Don`t overgrease the fittings or it gets back to the top of the valve and makes the same mess you started with! Dave C.
Post A Followup
: Re: Re: Re: a lift
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
