Farmall Tractors Discussion Board
Re: Re: slipping clutch
Posted by carl in nc on August 06, 1999 at 04:31:13 from (205.188.197.173):
In Reply to: Re: slipping clutch posted by Don on August 05, 1999 at 20:28:55:
ta linkage is missing and i assume ta is not woking. main clutch linkage seems to be correct. is there any way the ta can slip behind the main clutch if the ta low range is not working and everything is just on direct drive from main clutch to transmission?
Post a Followup
: Re: Re: Re: slipping clutch
