Re: The H runs again
Posted by The Red on April 09, 2002 at 15:44:52 from (12.84.239.92):
In Reply to: The H runs again posted by KURT on April 09, 2002 at 15:42:45:
Kurt you are real close on the timing. I usually set them at the highest RPM sound at idle. If one of my Hs or M has a slight miss, then I retard the timing about 5 degrees. If it is starting real easy, then you have the timing wired!!
Post A Followup
: Re: Re: The H runs again
