Re: Re: Question for gene b re; A exhaust-lift
Posted by DAVE C on April 09, 2002 at 18:50:32 from (209.197.177.127):
In Reply to: Re: Question for gene b re; A exhaust-lift posted by bob on April 09, 2002 at 15:45:19:
Bob; when you work the lever in and out, you should actually be in contact with TWO linkages, one to the exhaust manifold cut-off and the other to the control valve. are you missing or have a damaged second linkage? if missing, you will have to copy one from another tractor. Dave C
Post A Followup
: Re: Re: Re: Question for gene b re; A exhaust-lift
