Re: Re: Question for gene b re; A exhaust-lift
Posted by DAVE C on April 10, 2002 at 05:25:47 from (209.197.177.135):
In Reply to: Re: Question for gene b re; A exhaust-lift posted by gene b on April 09, 2002 at 19:46:18:
gene b; found it!! Completely sealed up tight with dirt and grease, you couldn`t tell that it was a hollow tube. do you have any way of posting a picture of your mounted cylinder? you mentioned a top brace and i know that i don`t have that or where exactly it would attach if i were to make one. my cylinder (and the left light) vibrate a lot at present. thanks a lot !! how about this forum : you help someone with something that you`ve run into before and someone else helps you on the same topic! Dave C
Post A Followup
: Re: Re: Re: Question for gene b re; A exhaust-lift
