Re: H brakes to SH brakes
Posted by RPM on April 10, 2002 at 07:09:56 from (63.110.182.225):
In Reply to: H brakes to SH brakes posted by cd on April 09, 2002 at 18:55:59:
It would be a costly and complicated job, lots of things different, mainly the brake pinion shafts and housings, H band brake are keyed on to drum, Super has splined shaft for the discs, if you dont do a lot of plowing I would just keep the band brakes for general use. Neither was perfect, disc was for higher heat when you braked the land wheel in plowing, more maintenance needed, band brake was more stopping power for general use.
Post A Followup
: Re: Re: H brakes to SH brakes
