Farmall Tractors Discussion Board
Re: Setting the float on Super A
Posted by Phil Auten on August 06, 1999 at 05:35:20 from (206.175.72.226):
In Reply to: Setting the float on Super A posted by Marvin on August 04, 1999 at 15:37:50:
Marvin,
There are two (at least) possibilities. The float could now be too low for high speed operation or the high speed jet may need some adjustment. I had a similar problem on my M and fixed it with the high speed adjustment. Get a manual, an I&T form the local farm store should do, and try the adjustment first. Then if that doesen't work, adjust the float a little at a time until the problem goes away. Running for a long time with a lean condition will burn the valves, so don't wait very long to fix this.
Phil
Post a Followup
: Re: Re: Setting the float on Super A
