Re: M with a cracked cylinder wall
Posted by Al R. on April 10, 2002 at 18:46:50 from (205.188.199.166):
In Reply to: M with a cracked cylinder wall posted by Ted on April 10, 2002 at 16:51:23:
Ted, M's have dry sleeves in them. More than likely it is cracked behind the sleeve. Any good machine shop could bore the hole and install a repair liner in it and then bore the liner to fit the sleeve. I have done this on a Super M I own.
Post A Followup
: Re: Re: M with a cracked cylinder wall
