Re: what model plow have I found?
Posted by Hugh MacKay on April 11, 2002 at 01:49:34 from (216.208.58.115):
In Reply to: what model plow have I found? posted by red reaper on April 10, 2002 at 20:41:41:
It sounds to me like you have a IH No60, built in 60s they do have McCormick written on the main beam. The letters SC stand for Super Chief as in the type of molboard. Does it have a point about 4-5" wide and about 15-18" long with actual point protruding at one end. It may have a trip hitch or trip bottoms. If it has trip bottoms they will be identical to bottoms on early IH semi-mounts or mounted plows built in 60s The dished coulters were an option from late 50s through late 70s anyway maybee longer. The coulters are a single yoke and came either shear bolt or spring protection. Hub of coulter has two tapered bearings with a grease zerk.
Post A Followup
: Re: Re: what model plow have I found?
