Re: Re: filters
Posted by Diesel Don on April 11, 2002 at 13:00:28 from (141.129.1.112):
In Reply to: Re: filters posted by Dave_Id on April 11, 2002 at 12:02:57:
I have a Dodge truck with a Cummins engine.The only filters allowed by warranty are Fleetgard,Case IH,and Mopar.The other after market filters would disintegrate under the high oil flow on these engines.The fibers would then plug the piston cooling nozzles causing eventual wrist pin and or total piston failure.I got a letter from Chrysler about this.Don't take a chance-use the best!
Post A Followup
: Re: Re: Re: filters
