Re: 3-pt Hitch Assembly
Posted by Zonie on April 11, 2002 at 21:11:50 from (152.163.197.206):
In Reply to: 3-pt Hitch Assembly posted by The Undertaker on April 11, 2002 at 18:50:42:
Undertaker,
You can use your three point using the one way hydraulics from your liftall just by hooking up 2 half inch hoses to the outlets that are opposite each other on the tractor. BUt if you want 2 way hydraulics you will need a single spool open center valve. plumb one of the outlets to the valve inlet, return from the valve will need to be tee'd into the belly pump via the dipstick fitting on top or into the drain plug in the bottom.
You will need to run hoses from the valve to both ends of your cylinders.
KLF has good info also.
Post A Followup
: Re: Re: 3-pt Hitch Assembly
