Re: Re: filters
Posted by Check this out on April 12, 2002 at 06:05:59 from (66.191.112.67):
In Reply to: Re: filters posted by Poppin' Johnny on April 11, 2002 at 17:06:24:
Almost all vehicles with a full flow oil pressure system have a by-pass valve located in the lube circuit. Now check this out. If you start any vehicle, be it tractor, truck, bus, car or what have you, at 0 degrees or below, how much of that oil is filtered, until it reaches operating temperature? Well fellows guess what? Very little. So make sure the oil stays clean! AND you won't even find an honest engineer that will tell you this I bet. I worked on many different kinds and found the seats so bad on that by-pass that it was easier for the oil to go that route than thru the filter, consequently causing a lot of
bearing damage. Check it out.
Post A Followup
: Re: Re: Re: filters
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
