Re: 706 Hydro Problem
Posted by Ace Schrunk on April 12, 2002 at 12:43:33 from (65.103.166.170):
In Reply to: 706 Hydro Problem posted by Craig on April 11, 2002 at 18:29:39:
You can not adjust the relief valve if the valve you added was used it might be warn enough so the oil is going bast it that is fault of spool valves. what kind of plow pull type or semi mounted.
Post A Followup
: Re: Re: 706 Hydro Problem
