Re: 706 Hydro Problem
Posted by Old Dutch on April 12, 2002 at 17:58:49 from (66.191.112.67):
In Reply to: 706 Hydro Problem posted by Craig on April 11, 2002 at 18:29:39:
Craig, if you are pulling a semi-mounted pull type plow, and it is going deeper as you are plowing, you have to adjust your draft lever next to the raise and lower lever for the hitch. It is the outside lever. This controls the draught or pulling force of the tractor, which in turn transfers weight to the back wheels of the tractor to control spin or traction of tractor and easing the plow up or down as it goes. The back end of plow you would control with your regular hydraulic lever. Hope this helps.
Post A Followup
: Re: Re: 706 Hydro Problem
