Re: 966 Hydraulics
Posted by red baron on April 12, 2002 at 19:27:06 from (208.231.183.206):
In Reply to: 966 Hydraulics posted by BrianS on April 12, 2002 at 18:29:59:
Be sure to pay close attention to the o-ring between the pump mounting plate and the rear frame of the tractor. Sometimes the port in the plate and in the frame of the tractor are not in alignment and this will cause the o-ring to blowout. If this is the case I usually have the recess that is in the mounting plate machined wider to accept a teflon o-ring. The teflon o-ring is the one used between the rear frame and the rear frame cover. After this fix the ring will not blow again.
Post A Followup
: Re: Re: 966 Hydraulics
