Re: LIFT ALL - Dip Stick for an M Farmall
Posted by Chris on April 12, 2002 at 19:52:32 from (65.69.164.232):
In Reply to: LIFT ALL - Dip Stick for an M Farmall posted by BIG JOHN on April 12, 2002 at 16:57:27:
I did something similar.I did'nt have the original oil fill cap so i used a 3/4" pipe cap drilled a 1/8" vent hole in the side and drilled a 1/4" hole in the top then welded in a 12"
piece of 1/4" smooth rod but until I read this I did'nt know where to put the full mark . thanks
Post A Followup
: Re: Re: LIFT ALL - Dip Stick for an M Farmall
