Farmall Tractors Discussion Board
450 Frozen
Posted by Bill(Tx) on August 06, 1999 at 13:33:02 from (192.105.235.146):
I've been working for months to unstick one or several pistons from a '57 450 without any progress. Tried ATF, pentrating oil, marvel, in every brew known to man. More ATF, rocked her, more ATF, through this cycle for 5 months.
So instead, I think I'll try this..pull the valve cover, remove the rocker arms, remove the push rods, then pull the head. Then pound the stubborn pistons into submission. I don't plan an overhual just yet because the engine ran well before freezing. Do I have the dissassembly process correct, and is the assembly in exact reverse order? I'll renew or grind the valves if necessary and generally clean-up.
Post a Followup
: Re: 450 Frozen
