Re: Farmall A steering loose
Posted by Haas on April 13, 2002 at 12:02:40 from (129.37.117.124):
In Reply to: Farmall A steering loose posted by Keith on April 13, 2002 at 05:45:46:
Common problem. No adjustments on these things other than makeing sure all the linkage on the tie rod side are good and tight. You can check the worm gear bearing by taking out the big plug in the front of the steering box. Then you can hold the wheels straight and screw out the worm gear and bearing far enough to examine. If you want it all the way out, you have to remove the steering wheel. The worm gear and shaft are all one piece. The the ball bearing on the worm gear has any play, you can replace it and that will help your steering play. If that does not tighten it up, they you will have to take off the steering box and rebuild it with new bearings. Hopefully you won't need new gears.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
