Re: Farmall 560 Diesel power steering
Posted by Ace Achrunk on April 14, 2002 at 08:22:47 from (67.233.161.72):
In Reply to: Farmall 560 Diesel power steering posted by Kevin on April 13, 2002 at 19:39:38:
The valve is in the front end casting with the rack, the splined shaft that the front U joint goes on must be able to move back and forth a little to activate the valve. so check to see if this can happen, if u joint is rusted on splines see that the whole shaft all the way to the steering wheel can move a little. 560 has two pumps pigie back is for power steering and relief valve is on pump. hope this helps some.
Post A Followup
: Re: Re: Farmall 560 Diesel power steering
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
