Re: Starter or battery or what???
Posted by Mr. J on April 14, 2002 at 10:46:29 from (64.200.53.43):
In Reply to: Starter or battery or what??? posted by Kevin Bassett on April 14, 2002 at 07:23:39:
Kevin,
Have your battery tested, you probably have a short inside your battery. It might show that it will take a charge, but it won't ever turn like it should. You said that you tried jumping it from an SUV....the cables you use don't hardly carry enough to start the tractor on the SUV battery power alone through the cables, the resistance and length of the cables won't hardly let it work. But, if you take your battery off of the SUV, put it on your tractor, it should crank it right up. Another thing, pop your battery off, take it to an auto parts store and they can test it right there. You could also try jumping your tractor directly to the starter from your SUV. I'll bet it's a bad battery though. Good luck, let us know how you come out.
Jared Jeffries
Post A Followup
: Re: Re: Starter or battery or what???
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
