Re: 5488 hyd. lever detent not working
Posted by kal on April 14, 2002 at 19:08:43 from (63.11.138.216):
In Reply to: 5488 hyd. lever detent not working posted by red reaper on April 12, 2002 at 20:42:29:
Might check your flow control.If it's set to high for the size of hoses you have it will do the same thing.If you have smaller hoses the pressure build up at high flow rates kick the valve back to neutral.
Post A Followup
: Re: Re: 5488 hyd. lever detent not working
