Re: Farmall Super C!...Somebody talk me out of it!
Posted by Haas on April 15, 2002 at 06:16:50 from (129.37.117.16):
In Reply to: Farmall Super C!...Somebody talk me out of it! posted by Scott L. Swanson on April 15, 2002 at 06:03:10:
Yes, it'll cut tall grass. Depending on size of cutter, you may be in low gear if the grass is heavy. Parts are easily obtained at any IH dealer and lots of other places. You can put a loader on it, although not very commonly done. You can put a blade on it, but it will not be easy to find a front dozer blade. They exist, but are not common. Pretty easy to work on, old tractors are pretty simple. If the engine runs good and does not smoke and all the gears work, it has oil in it , the radiator does not leak, you are probably OK. Look at the engine block behind the carburator for cracks or repairs. That is where the blocks crack if somebody messed up and did not keep the antifreeze up. Check the tires for condition, and the rims to see if rusting due to calcium chloride solution leaks. Repairing rims and replacing tires is a chore and expensive. Sounds like you've got an IRS check and the Farmall fever, a deadly combination!
Post A Followup
: Re: Re: Farmall Super C!...Somebody talk me out of it!
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
