Re: Re: Removal Of Raditator??
Posted by Steven@nd on April 15, 2002 at 06:24:12 from (165.234.131.150):
In Reply to: Re: Removal Of Raditator?? posted by boog on April 14, 2002 at 21:01:01:
Your procedure is correct except that you do not have to remove the cotter pin and castle nut on the steering shaft, it will all come out together.
Steven
Post A Followup
: Re: Re: Re: Removal Of Raditator??
