Re: Farmall Cub brakes
Posted by Nat on April 15, 2002 at 19:44:38 from (66.56.167.253):
In Reply to: Farmall Cub brakes posted by Scott on April 15, 2002 at 16:39:21:
It is a good possibility that the anchor pin for the brake band is bent, or broken. You will have to remove wheel/tire, then final drive at fender, the anchor pin fits into a hole in axle housing and a hole in final drive housing . If that is the problem, it isn't a hard fix, hope this helps,Nat
Post A Followup
: Re: Re: Farmall Cub brakes
