Re: Super C length and width
Posted by BIG JOHN on April 16, 2002 at 20:39:46 from (64.12.102.37):
In Reply to: Super C length and width posted by Jerry on April 16, 2002 at 18:56:19:
Doesn't look like you are getting any posts. I can only tell you about the "C" but I believe that the numbers are the same for the Super C. The over all length is 120 3/8". The over all maxium width to outside edge of rear tires tires is 89 3/4" (this would be with the standard 88" axels)100" rear axels were available and would change this measurement. The minimum width would be 88".
Tread width on the tricycle front end can be 6 3/4", 9 1/2" or 12 3/4" depending on how you mound the wheels on the hubs.
Tread width on the rear end is 47" to 71" with the wheels turned in, with the wheels turned out the tread is 56" to 80" Tread width for the 100" axels is not given.
Source: IH, McCormick - Deering, Farmall "C" Owners Manual.
HOPE THIS HELPS
Post A Followup
: Re: Re: Super C length and width
