Re: F-20 oil pressure?
Posted by brianh on April 17, 2002 at 06:30:48 from (216.153.236.122):
In Reply to: F-20 oil pressure? posted by Dave on April 17, 2002 at 02:50:04:
The oil gauge on my F-20 was bad and I put a low range direct reading gauge on it and it showed 5-15 PSI between idle and full speed hot. I just got the supposedly correct gauge from Rice and put it on and it reads about 2/3 scale, so I think my pressure is OK????? Assuming this is right, 20-40 might be a little high. The popoff valve is in the filter base so it's not to hard to get to and check.... Brian
Post A Followup
: Re: Re: F-20 oil pressure?
