Hydraulic pump trouble keeping engine from starting?
Posted by K.B. on April 17, 2002 at 17:56:07 from (209.163.14.202):
Just finished some hyd. work on my 240. Now it won't start. Has gas to the carb. and a good spark. It ran great before. When I put the hydraulic pump back together, it felt a little tight. I filled it with Hy-Tran and loosened the two bolts holding it together, then it felt a little better. My question is, if the pump is a little hard to turn, can it make the engine hard to start? Or mabey any other hydraulic trouble-like too much pressure somewhere?
Post A Followup
: Re: Hydraulic pump trouble keeping engine from starting?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
