Re: Regular Bush Hog Behind A Cub
Posted by Kenny on April 18, 2002 at 13:02:35 from (170.76.19.10):
In Reply to: Regular Bush Hog Behind A Cub posted by Michael Hughes on April 18, 2002 at 12:33:25:
Hello:
The Cub PTO is not a standard pto. To do it, you will have to get a pto adapter that will convert the cub pto to the standard speed. You can not just hook up it up directly as it is. I have never used an adapter, but have a couple cubs. You are very limited what you can do with the pto on the cub. That is why you have to get special equipment made for the cub. Someone else will answer this better, but I believe the Pto on the CUB is engine speed, and reverse direction?
That is my two cents worth. Kenny
Post A Followup
: Re: Re: Regular Bush Hog Behind A Cub
