Re: Re: K.B. and other fellow 240 owners
Posted by Mark-NC on April 18, 2002 at 21:14:34 from (165.247.160.166):
In Reply to: Re: K.B. and other fellow 240 owners posted by JimBinTexas on April 18, 2002 at 18:25:31:
Hi Jim, I've done some limited work on my 240-U steering box. Had to take the steering gear out because the woodruff key sheared. I ended up having to cut another key slot 180 deg. on the shaft because the original one was too worn. I removed the front axle, lower bolster, and the retaining ring that holds the gear in. At that point, you can remove the universal on the worm gear shaft (and front cap) and slide the worm gear out. The castle nut on the shaft holds only the bearing on. If you decide you need a replacement, be aware that tractors with power steering had 25 teeth on the steering gear, while ones without used a lower gearing (50 teeth). Be sure to match it with what you have. I've noticed on mine that quite a bit of steering slack is coming from worn tie rods and worn universals on the steering shaft. I'll try to tackle that next. Some steering slack can also be taken up by rotating the steering gear 180 deg. Hope this helps some. It's not a terribly difficult job unless you do have to find some replacement parts. Good luck. Mark
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
